exhaust ticking??? - FirebirdV6.com/CamaroV6.com Message Board
exhaust ticking???
  • exhaust ticking???
    ok i just put on headers about 3 weeks ago. the first day i put them on my car was ticking and i realized the EGR valve wasnt in all the way so i tightened it up then the ticking went away. A few days ago the ticking came back but i checked the EGR valve and its sealed nice and tight. Also i welded the Y pipe onto my cat so theres no air leaking there. I tightened up my header bolts yesterday cause most of them were loosened up so i figured the ticking would go away cause that was the problem. I cant find where its comming from now. When im ideling there is no ticking what so ever so i dont believe its an internal problem with the motor. But when im accelerating it starts ticking as as my RPMS increase the ticking speeds up just like when my EGR valve wasnt tightened the first time. Any idea's on what it could be??
    Juiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
    Re: exhaust ticking???
    Check where the headers bolt up to the y pipe. Thats probably where its leaking from. If it is no matter how tight you tighten them they will loosen up over time. I have to get mine retightened about every six months.
    <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
      yah i also did that....i took the bolts off and added lock washers cause i noticed they loosen up also and i thought thats where they were also leaking from. Honestly im clueless right now as to what it could be. I checked my vacume lines also and no leaks
        what gaskets you using ?
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          the paper ones that came with it i believe? i bought them brand new off a member on this board...they were white paper ones
            they probly blew out
            get some from abbott racing heads, those paper gaskets suck
              ok i figured out what it is....viper you were right...on the right headers in the lower left hand corner the gasket blew out.
