How hard to put on headers on an 01 Camaro - FirebirdV6.com/CamaroV6.com Message Board
  • How hard to put on headers on an 01 Camaro
    Umm on a scale of 1 - 10 about how hard is it to get headers in that little area? Let me know thanks.
    Re: How hard to put on headers on an 01 Camaro
    4ish ;)
    \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
      what is your mechanical skill? do you have some basic tools like wrenches, sockets and accessories? if you some of both, i would say its about a 5ish
      2000 3.8 A4 Pewter Camaro
        back a while, when i did it, it took me about 1 day, working at a steady, but relaxed pace. the majority of the time will be spent removing heat shields, assuming its like the log style manifolds.
        Visit My F-Body Page
          took me about 6 hrs, I have a header install guide in my sig
          http://www.bowtiev6.com/
            I had my headers on the engine in 3.5 hours...the hard (long) part about my header installation IMO was getting the Y pipe, cat, and S pipe welded together. And some people don't even do a bigger cat and S pipe. My whohle project took 8 hours tho, with new headers, spark plugs, cat, and building an S pipe.
            1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
              taking apart the engine or doing a head gasket swap, i would say without a doubt the hardest thing is the damned exhaust manifolds. I hate the heat shields. When you twist on/off the heat shield bolts the heat shield will twist and its reallly hard to get a socket or wrench on the bolts! I ended up cutting the heat shields off of the heat shield bolts. That makes my job alot easier and it doesnt vibrate or anything.
              I would recommened a impact wrench, a deep socket 13mm, a long 13mm wrench, and a 13mm ratcheting wrench.
                I've heard since you already have good flowing tubular manifolds that adding headers won't give you much gain, unless maybe you had extensive modding too.
                  yea, hes got an 01 so tubular manifolds are pretty good, enough. I would only do it for sound quality or if I had done every mod in the book and had extra $
                    Not wanting to start another thread: How much would having them professionally installed cost (about)? I've heard its quite expensive.
                    Originally posted by SSMOWS6
                    i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
                    R.I.P. '07 Pats
                    Still... 18-1 > 1 and done
                      meineke did mine for 400
                      Dave:
                      00 Supercharged Camaro - RIP
                      97 Turbo Camaro - Sold
                        I shopped around and got quotes from 600-1000 so I did em myself. Took 6 hours with plenty of breaks and that includes welding it to the hi flow cat on and welding it to the rest of the exhaust.
                          Thats quite expensive quotes!
                            Wow, thats not worth it at all... Sucks for me then, theres no way i could install them myself: 1. I have v. little patience for these things. 2. I can't weld
                            R.I.P. '07 Pats
                              www.turbov6camaro.com/header.htm
                              1997 3800 Series II Camaro
