Want to do full exhaust need some help - FirebirdV6.com/CamaroV6.com Message Board
  • Want to do full exhaust need some help
    I want to do full exhaust on my 97 3.8 to get it breathing and sounding better but i dont know where to start.
    I know im gonna get
    Pacesetter mid length headers
    Pacesetter TFX exhaust
    electronic cut-out
    but i see you guys using mid pipes and s-pipes. where do these go and where can i buy them. if i buy one do i need the other.
    with intake and tuning do yall think i could get low 14's?????? its an a4....
    Re: Want to do full exhaust need some help
    you can get a s pipe custom bent at any exhaust shop. i found it to be cheaper and i'm very happy with what i have.
    i don't think that you should get pacesetter for the muffler system. i would say go with a flowmaster. i've heard alot of bad stuff with muffler and rust. you will be fine with their headers.
    why are you going to run a cut out?
    i don't think that you will get low 14's with that set up. depending on what you run now, i would say high to high-mid 14's.
    WAWA-A-HOLIC
      S pipe goes after the cat, bends the pipe over to go beside the driveshaft, "mid" pipe goes beside the driveshaft, then you go over the rear axle. put your car on ramps and crawl under there, it is really obvious what needs to be done once you look at it. you need to look under the passenger side.
      "S" pipe can be made by cutting a "U" pipe in the middle, flipping one end and rewelding it back together in shape of an "S"
        Wow! look what i found :)
        How To's and FAQ's! Read This First
        I also, do not recommend the Pacesetter cat-back and also do agree to get the flowmaster but listen to exhaust sound clips first.
        I also agree that you probably will not run low 14s with just intake, exhaust, and tuning but it is possible.
        2000 3.8 A4 Pewter Camaro
