I was wondering can I use a Slp CAI with K&N FIPK? I would think I would have to do some modifications with the heatshield, but would it benefit it? More cold air from the bottom? Thanks
Can I use a Slp cold air lit to enhance K&N FIPK?
Re: Can I use a Slp cold air lit to enhance K&N FIPK?
Anything you can do to make it get colder air, or keep the air cold, including ridding of the rubber elbow, is going to give you an improvment. Weather its noticible or not is not so likely. But if it in turn causes easier flow or cooler air, you are making it work better.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
i should be installing an slp with the fipk maybe monday i will let you know if i feel any diff. in power2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
Originally posted by vr4gasmi should be installing an slp with the fipk maybe monday i will let you know if i feel any diff. in powerK&N FIPK, Pacesetter Headers, Carsound Highflow Cat, 3\" Magnaflow catback, 180 Thermostat, 8.5 MSD Wires, NGK Plugs, Chrome ZR1 Rims
Originally posted by Nikos95Anything you can do to make it get colder air, or keep the air cold, including ridding of the rubber elbow, is going to give you an improvment. Weather its noticible or not is not so likely. But if it in turn causes easier flow or cooler air, you are making it work better.K&N FIPK, Pacesetter Headers, Carsound Highflow Cat, 3\" Magnaflow catback, 180 Thermostat, 8.5 MSD Wires, NGK Plugs, Chrome ZR1 Rims
i will for sure post pics of the install as long as it doesn't rain monday it is for sure getting installed then2001 Camaro 3.8 A4
1991 3000GT VR4
Originally posted by SexySixer707Is the rubber elbow the black piece in between. What is that called?
2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
1974 Silver Chevrolet BIG BLOCK Corvette
Originally posted by QuestionThe air silencer?K&N FIPK, Pacesetter Headers, Carsound Highflow Cat, 3\" Magnaflow catback, 180 Thermostat, 8.5 MSD Wires, NGK Plugs, Chrome ZR1 Rims
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...5 days ago
