Slight problem with new exhaust... - FirebirdV6.com/CamaroV6.com Message Board
  • Slight problem with new exhaust...
    So I just put in my new exhaust system and I have a problem. I installed the Carsound hi-flow cat, and the 3" cat-back Flowmaster system. Now my problem happens right after my S-Pipe, the exhaust is too close to the driveshaft and if I hit the wrong bump, the exhaust hits the driveshaft. Does anyone else have this problem? And does anyone else know how to fix this?
    Re: Slight problem with new exhaust...
    pic's would help, at least for me becuase im a little confused. did you install it or have a shop do it? if you had a shop do it, just take it back and tell them. so its not the S pipe hitting, its the start of the I pipe? and are you 100% thats what/where your hitting? odds are you just have to play with it a little bit and it'll stop.
      You have a 3" system right? The first muffler shop i took mine too said that that might happen, the second said it wouldn't be a problem. If you just take it to a/the muffler shop they can readjust it.
      Originally posted by SSMOWS6
      i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
      R.I.P. '07 Pats
      Still... 18-1 > 1 and done
        Yeah, I just got it on today, and at first it was clamped at all the connections. Right where the S-pipe joined to the exhaust was the one clamp, and you can see a fine line on the drive shaft of where the clamp kept getting hit, so I had it welded, but it still bumps when I hit certain bumps. I figured they could fix it one way or another, so chances are Ill take it back Wed. morning and see what they can do. Thanks though.
