So I just put in my new exhaust system and I have a problem. I installed the Carsound hi-flow cat, and the 3" cat-back Flowmaster system. Now my problem happens right after my S-Pipe, the exhaust is too close to the driveshaft and if I hit the wrong bump, the exhaust hits the driveshaft. Does anyone else have this problem? And does anyone else know how to fix this?
Slight problem with new exhaust...
Re: Slight problem with new exhaust...
pic's would help, at least for me becuase im a little confused. did you install it or have a shop do it? if you had a shop do it, just take it back and tell them. so its not the S pipe hitting, its the start of the I pipe? and are you 100% thats what/where your hitting? odds are you just have to play with it a little bit and it'll stop.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
You have a 3" system right? The first muffler shop i took mine too said that that might happen, the second said it wouldn't be a problem. If you just take it to a/the muffler shop they can readjust it.
Originally posted by SSMOWS6i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
Still... 18-1 > 1 and done
Yeah, I just got it on today, and at first it was clamped at all the connections. Right where the S-pipe joined to the exhaust was the one clamp, and you can see a fine line on the drive shaft of where the clamp kept getting hit, so I had it welded, but it still bumps when I hit certain bumps. I figured they could fix it one way or another, so chances are Ill take it back Wed. morning and see what they can do. Thanks though.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...9 hours ago
