Does Everyone with Pacesetter's get o2 Slow to Respond Codes? - FirebirdV6.com/CamaroV6.com Message Board
  • Does Everyone with Pacesetter's get o2 Slow to Respond Codes?
    I installed my pacesetters about 2 weeks ago and put 2 new o2 sensors at the same time. Now I'm getting these codes p0133 and p0153 both are "slow to respond".
    I've done some searches and a lot of people seem to have had this problem. Most of the posts end on getting an o2 sim... but you can't put a sim on these sensors and I already have a sim after the cat.
    This is going to drive me nuts and I need to get it fixed for the Massachusetts Enhanced emissions test. Has anyone been able to solve this without getting a tune?
    Justin<br /><a href=\"http://www.bass482.com/firebird/index.html\" target=\"_blank\"> 2000 Black Firebird A4 Y87<br /></a>170.2rwhp/203rwtq (SAE Corrected)
    Re: Does Everyone with Pacesetter's get o2 Slow to Respond Codes?
    I hope to hear more on this as I will be installing some Pacesetters soon. I don't need to see any issues crop up when done.
    1996 Camaro. \"RedKnight\" on MOFBA.org.
      do u live near Rt9? and r u on NeFbody.org?
      87 Firebird RIP
      96 Camaro RS RIP
      94 Patriot Red 1LE Z28 - Sold
      02 WS6 TA - Sold
        I've never had any codes for o2's pop up on my car and it still has the stock o2's.I've had my pacesetters on for two years now.
        <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
          i was pulling one code. which was my rear sensor. put a casper sim on there and i'm good to go
          WAWA-A-HOLIC
            Yep. Just off of Rt. 9. Never been to to that site. I'll check it out.
              My 97 3.8 has SLP cold air, pacesetter headers, and full 3" exhaust w/ a highflow cat and all the O2 sensors are in place and working, no codes. (knock on wood)
                i've got pacesetters, i don't use any o2 sims and i haven't set any codes off, except for an egr code which went away after a little liquid gasket.
                K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
                  I installed the Rk sport headers and threw a code for bank 1 sensor 1. I just replaced with with a new bosch sensor and erased the code with a scan tool. I've only driven the car 15 miles since I replaced it and no new code. Try putting in the original o2 sensors.
                  69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
                    I have pacesetters, I sometimes get a bank 2 sensor 1 heater code but it doesn't trigger the SES light or anything. I can just see it pop up on my hp tuners. I think it is in my wiring though because I tried another stock 02 sensor and it was still there. No biggy to me cause it still runs fine and a/f is all good
                    http://www.bowtiev6.com/
                      i was getting a code, and i even tested the o2 sensor with a sensor tester and torch to make sure it was still working. it was, but eventually i got a new one anyway, and the code went away. fresh sensors seemed to do the trick for me.
                      Visit My F-Body Page
                        I just installed new o2 sensors yeterday. Let's keep our fingers crossed!
                          I got the same codes when I got headers. I got the pcm tuned and that fixed my problem.
