Illegal..maybe...but worth it? - FirebirdV6.com/CamaroV6.com Message Board
  • Illegal..maybe...but worth it?
    So I've heard that i can just remove my cat and get some hp. i've got the 3.8 running probably around 215hp now. If i were to take off my cat, first off..how would i go about doing so, and second, would i gain some hp? i mean..how much?
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
    Re: Illegal..maybe...but worth it?
    just unclamp it or if its welded take it to a shop and have them put a straight pipe in its place(what i did, since mine was welded on one side and not on the other) you'd gain a FEW horses(not sure the exact #) from what ive heard, i felt a difference when i ditched mine, downside is it is a bit more raspy up top but i heard, which i plan on doing, that if u put a bullet muffler in its place it will take away some of the rasp.
    \"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
      First off, what do you have done to your car to get 215 hp?? You realize stock our cars dyno like 160-180hp right....
      Next, all you need to do is put a piece of straight pipe where the cat was. Any shop that doesn't mind taking the cat off a car can do it. Let me warn ya, a lot of shops are gonna say "no" to you doing this though cuz they can get in trouble. Another option is to go with a hi-flow carsound cat in its place.
      Moving to exhaust
      http://www.bowtiev6.com/
        i know, i haven't dyno tested my car, so i'm just guessing...shot in the dark. I have a cold air intake and dual exhaust..i figured i might be somewhere in that range. I know i may be wrong though.
        As far as installing the straight pipe...is that something i can do by myself fairly easily, or should i have a shop do it...and how much is that going to cost me?
          id recommend going with a 3" high flow, for three reasons. Dont have to worry about passing inspections, hp gain is going to be 99% of the same as straight pipe, and is going to better.
            yeah i've got a hollowed and sleeved cat with a 3" open borla cat back..sounds awesome
            ____________________
            12 SECOND NITROUS POWERED 98 A4 V6 CAMARO
            www.MySickCamaro.50megs.com
            SOON TO BE FEATURED IN CAMARO WORLD MAGAZINE!
              Actually, if you're in a state without instpections like me I'd disagree. Hp gain is more (need everything you can get with our cars) and won't have to worry about it rattling after a few thousand miles like mine did. Getting my high flow off soon, the rattling piece of ****.
                I don't plan on getting a new cat, if anything i would remove the one i have, but does anyone know how hard it is to do it yourself/how much it is to have it done? (the straight pipe)
                  Its not hard if you have the right tools, i went from stock to highflow to a dyno max bullet now. a sawzall is really all you need, a few sockets too. its welded on both sides so youll have to cut it off. stock y-pipe(before cat) is 3 inches, the s-pipe(after cat) is 2 1/4 inches so youll need a reducer.
                  without the cat def makes the most power, out of all the setups.
                    Thanks everybody.
                    does anyone know how much hp i will be looking at when i do this mod?
                      There's always the option of gutting the cat. If you have inspections, you can usually get away with just gutting it, still get some gains, and it's seen as legal.
                      ~97 3.8L V6 Camaro~
                      A few things
                      Only Member of Team Hooker?!?
                        i'm assuming i would still get more performance gain through a straight pipe though over gutting the existing cat? If i were to replace with a straight pipe, 1. how much would it cost me to have it done
                        2. Would there be anything else that i should do to get ready for this? or is it alright stand alone. The only real mod i have on my car is a cold air intake by K&N. i have the Y87.
                          chances are you'll lose some torque yet another reason to stick with a high flow cat
                          2001 Camaro 3.8 A4
                          1991 3000GT VR4
                          2001 Mitsubishi Eclipse GS
                            you will DEFINETLY lose torque off the line and will throw a code too. You will need an 02 sim. if you are going to go thru with this.
                              its gunna sound raspy liek **** though man ... my car has a gutted cat and it gets raspy as **** so i dunno if ud wanan do that
                              <a href=\"http://photobucket.com/albums/a371/boyoi/firebird/?sc=1\" target=\"_blank\">My FireBird</a> K&N intake,Gutted cat, glass pack muffler.........Lots more to come...... <br />Getting my exhaust soon :)Rumbler Exhaust w/ Hooker\'s Headers :)
