i just picked up the abbot racing gaskets for my pacesetters. im putting them on today, but i was wondering whether i should use the ultra copper rtv that i used last time or if i should leave it off this time. the guy from abbott said i wouldnt need it. any opinoins? suggestions?
rtv/permatex on header gaskets?
Tags: None
Re: rtv/permatex on header gaskets?
Maybe a very thin bead of silicone on them, but if there is any little gap between the gasket and head, the exhaust will blow-out the silicone within a short amount of time. Personally, I'd just install the gasket alone, bolt up, drive until the engine gets hot then re-torque the bolts again.sigpic
well then thats what ill do
I used a thin layer over the entire surface of the header just to help hold the gasket to the header while aligning the screws to the head. Worked fine for me.Justin<br /><a href=\"http://www.bass482.com/firebird/index.html\" target=\"_blank\"> 2000 Black Firebird A4 Y87<br /></a>170.2rwhp/203rwtq (SAE Corrected)
yea I put a thin layer around the gasket on mine when I installed them
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...1 day ago
