i was changing out my muffler and took the old clamps off and it wont budge. i dont want to cut it. any tips to getting it off ?
replacing muffler tough to get off.
Re: replacing muffler tough to get off.
Try heating the pipe up with a torch. Get it nice and hot and turn the pipe or muffle to see if it loosens up. If that fails, spray the coupling ~heavily~ with WD40, let it soak for about an hour and then try turning the muffler. Basically, you want to break the seal that the pipes have. Once the seal is broken, getting the muffler off isn't too much harder.sigpic
^i wouldnt do that. if your not replacing the piping going into the muffler you run the risk of screwing up the pipe. try what hockeyman said. soak it in WD-40 or maybe some PB blaster. let it soak and the take a rubber mallet to it. it should knock it loose and because its a rubber mallet it wont dent up any of your exhaust'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
tried the wd40 no luck. i smacked it w/ a reg hammer, no luck i think i am gonna run it a bit to try to heat it up or something1997 Camaro LS1 RS
1994 Camaro - Sold
1999 Trans am Vert - Sold
A Few Mods....
Originally posted by bahpb blaster ftw, try it1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
The clamps that held my muffler on were so tight that they actually crimped the pipes together, so even after I cut the clamps off, it was impossible to pull the pipes apart. I ended up just cutting it off because I was planning on replacing more than just the muffler anyway.Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Originally posted by T-MillThe clamps that held my muffler on were so tight that they actually crimped the pipes together, so even after I cut the clamps off, it was impossible to pull the pipes apart. I ended up just cutting it off because I was planning on replacing more than just the muffler anyway.
I have a NAPA store close by. They sell a band clamp. Many diesel trucks use this for their chrome stacks. It is made of a stainless steel band about 3" wide. When you tighten this clamp, it makes a great seal and does not put crimps in your pipe or muffler. I used these 8 years ago when I installed the high flow cat and cat back. Last year I had to take the exhaust apart to replace the fuel pump. The pipe came out of the muffler with no torch or liquid penetrant.
However, they do cost about $7.00 each but well worth it.
DrTodd
(Looks better than the old u-bolt clamps and the dont rust.)Dr Todd
Originally posted by Dr ToddI have a NAPA store close by. They sell a band clamp. Many diesel trucks use this for their chrome stacks. It is made of a stainless steel band about 3" wide. When you tighten this clamp, it makes a great seal and does not put crimps in your pipe or muffler. I used these 8 years ago when I installed the high flow cat and cat back. Last year I had to take the exhaust apart to replace the fuel pump. The pipe came out of the muffler with no torch or liquid penetrant.
DrTodd
I wish they would have used those when they installed my muffler... could have saved me alot of timeRebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
