Upgrading exhaust - FirebirdV6.com/CamaroV6.com Message Board
Upgrading exhaust
  • Upgrading exhaust
    I already have a flowmaster catback installed, and I am looking to install headers and a new cat and since reading some past threads, a new s-pipe too. I was wondering where I can find abbot gaskets for pacesetters, locking bolts needed for the y-pipe, the "50 dollar high flow cat" that I keep hearing about but cant seem to find (heh), and a cheap s-pipe. If anyone knows any sites where I might be able to find this stuff I would appreciate the reply. Thanks everybody.
    Re: Upgrading exhaust
    cat - http://store.summitracing.com/partde...5&autoview=sku
    s pipe - http://texas-speed.com/shop/item.asp...d=317&catid=45
    cheaper S pipe - order a 3" U bend from jegs/summit, cut it in half, flip one side over and weld back together.
    locking bolts for the Y pipe - you should have it welded, along with the rest of the system.
    gaskets - http://www.abbottracingheads.com/gm3800.html
    locking header bolts - http://www.ftpp.net/V6/Exhaust/V6%20...er%20Bolts.htm
    ebay also has 3" inch cats for $50. anymore questions just ask.
      Thanks alot man
        not a problem, id get a U bend from jegs or summit for $20 or so rather than pay $70+ for the SLP install kit. heres a GREAT write up on how to make your own, if you cant weld it yourself just take it to a muffler shop it'll take them 3 minutes. or do what the write up says, and get a pipe expander, then just clamp them together http://forum.camarov6.com/showthread.php?t=67580
        good luck with the upgrades. oh yea, if you still have the stock plugs, now is a great time to change them. get the old manifolds off, take old plugs out, new plugs in. just becareful not to chip/crack the new plugs putting the headers in.
          Thanks again, I have been putting off doing headers but yesterday i almost got beat by a stock saturn sc2 manual, only pulling away after passing 60 mph. It was sad cause I thought I would beat the saturn easy with almost 75 more horsepower before mods. Heh. Anyway thanks alot.
            OOps I just realized that my flowmaster is a 2.5" system. Will the 3" y pipe from the headers, 3" s-pipe, and 3" cat make any difference in power if they are feeding into the smaller 2.5" exhaust?
              you'd make more power with the 3" catback, but its probally not anough to worry about. and 2.5" systems usaully sound better than 3" , the bigger the pipes the more its going to rasp ,crackle/pop ect. like when you go WOT and then let off.
                I haven't posted here in a while, but I'd have to totally disagree with you on this.
                I used to have on my 94 3.4L Camaro a 3" exhaust setup with a 3" high flow cat with a Flowmaster 40 series muffler, and it sounded extremely aggresive. It was VERY loud, but there was absolutely no rasp whatsoever. I also had on two 3" truck tips which made it sound extremely powerful. People would pull next to me and constantly ask me if it was a V8.
                I currently have a 2.5" inch exhaust setup and is nothing compare to my old one. I will be switching back into my old 3" setup in a few months, and will post sound clips when it's finished.
                  this thread is a little old, and this topic has been beaten to death. usaully 3" systems are more raspy than 2.5", mostly likely becuase they're louder ( so you hear the rasp more ) and more free flowing which causes rasp. 3.4's sound better than 3.8's, quite a bit better so im not doubting that your system sounded great on your car.
                    this cat would work right!!!?
