the EGR tube's bolt is frozen. i cant move it at all. ive sprayed a crap load of WD40 on it and have broken 2 sockets tryint to get it off.anybody have any tips? im tempted to try to saw through the exhaust manifold with my sawzall to get it out.
having trouble with the header install
Re: having trouble with the header install
LOL! 2 sockets? how you do that?
try PB Blaster, it werked fer me!2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
and i thought only chuck norris could do such a thing!
I used liquid wrench. Get 'R Dun!96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
just cut it and pretend like you were doing !EGR the whole time.2002 Silver Metallic A4 Firebird - All Options
Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
Your Mom or My Dad?
well i got pb blaster and it didnt work. now im thinking of cutting the egr tube and just pulling it out and the putting that in the new headers and getting an intermediate tube to fill the gap. think that would work?
a friend randomly brought a wrench that he could get enough torque and it started moving... finally. we got them all off. had to cut through one of the heat shield bolts bc it was so rusted wrenches would just strip it. got all the old stuff out and one of the new ones in (passenger side). but now i cant get the o2 sensor plugged back in im using new ones (bosch ones) and i cant connect it. i screwed it in the header first, but should i plug it in and then put the sensor in the header?
Originally posted by Gerboniuma friend randomly brought a wrench that he could get enough torque and it started moving... finally. we got them all off. had to cut through one of the heat shield bolts bc it was so rusted wrenches would just strip it. got all the old stuff out and one of the new ones in (passenger side). but now i cant get the o2 sensor plugged back in im using new ones (bosch ones) and i cant connect it. i screwed it in the header first, but should i plug it in and then put the sensor in the header?
did ur guys' kits come with a nut for the egr bolt. it doesnt screw in to the mount on the headers like it did the old manifold. so im having a leak there, and on the driver side o2 sensor. wtf is up with that one. also did all yours have some of the exhaust come out where the ypipe go over the tube infront of the cat?
The kit says it has an EGR hookup, but leaves you to improvise on how you actually do it. I had a plate over the EGR tube, and a nut and bolt securing it, but it got soo hot that it warped the aluminum. Now I tried a steel plate a hella liberal amount of J*B weld.
I bought my O2 sensor from a GM dealer and it screwed in fine. Harness was the right length too. Can't help you there.
Y-Pipe and Cat can be solved with exhaust wrap (found @ Pep-Boys) and then clamp that sucka down. Prolly wouldn't hurt to J*B that too lightly around where the pipes meet.
uggh now the friggen steering column is hitting the header. thinkin of grinding it down a bit to clear the header so i dont have to take it all off and dent the header. any other ideas.
i feel like im running into problem after problem over here
