I am planning on installing a Flowmaster 80 series muffler and a Magnaflow High Flo Cat on my 3.4 A4 Firebird. I currently only have a drop in K&N Fitler and I do not have headers. I was wondering if after having these installed will I notice a difference in acceleration and MPG. I was also wondering if the raspy sound I here in the exhaust clips are also noticable when the car is in gear and accelerating?
Will I notice a difference?
Re: Will I notice a difference?
No, you probably won't feel the difference and if you think you do its most likely only because you want to. You will hear a difference and yes flowmaster mufflers rasp.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
You probley will not see any gain, because you are bottlenecking your system. Its always better to start from the back foreward. If I were you I would get a Cat-Back system first, than the Cat, and then the headers. Because extra flow does you no good if it has to shrink back up into a smaller area.
1998 White Camaro 3800, A4, MagnaFlow Cat-Back, Zexel & 3.42's, Jet Chip Stage 2, Whisper Lid, and Ram Air.
yes you will. not just cuz you want to you actually will. hes going to do a cat-back and a high flow cat so where is he bottle-necking it? that is the set-up i have on my car and i notice a good bit of difference. anything to open up your intake and exhaust will notice a good difference. intake, high flow cat, and cat-back look for horsepower gains around 15-20 at the wheels at the most. the cat itself will make a big difference in sound. it made the flowmasters much louder. the cat-back itself never had too much rasp but once i put the cat on it did rasp a little up top but i personally think it sounds good.'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
