Magnaflow with pacesetter - FirebirdV6.com/CamaroV6.com Message Board
  • Magnaflow with pacesetter
    I'm planing on getting the magnaflow cat-back system with high flow cat. Over at ftpp.net they have the 3" magnaflow cat-back system for $365.19. I have the pacesetter as well to install with this and then all i need is just a 3" in/out magnaflow cat, the 3" Slp install kit (dont know if the 3" cat back comes with this or not) and then the catback?
    Also found this system at autopartswarehouse for $388.2 with free shipping. Compared to ftpp.net for $365 with $40 shipping.
    On magnaflows website this 3" system is for the 93-97 z28 camaros? I saw the sticky in the form about this but what all needs to be done to make this fit? Just the hangers? Does FTPP.net change out the hangers on this and sell it as a v6 kit?
    Thanks for the help
    Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
    Re: Magnaflow with pacesetter
    I am running the exact same system, pace setters and magnaflow, heres the thing.......If you are not going with a power adder the 3" system is WAY TOO BIG. Daily driving on it before I had my cam done, I definetly noticed a small loss in power right off the line.
    That system is only made for the Z, So when I bought it they had to weld in a new bung for the O2 after the cat. So the system now looks alright, fitment should be the same as a Z, but looks to be off centerd a bit, if I were you I would get a 2.5 system, unless boost is in your future.
      sorry hangers are another issue. They welded a solid piece of stell to part of the system, and it ended up punching thru, I had to have that fixed.
        Ok I will settle for the 2.5" magnaflow (# 15693) system. So as for the cat do they make a 3" in to 2.5" out with a single sensor? I know mangaflow has one that is 2.5 in/out with a single sensor hole (part #94136). What do i do about this b/c the pacesetter ypipe is 3". Sould i just use an o2 sim instead? Thanks again.
          Was also looking for stage 8 header bolts. Is ftpp.net the only place that carries these from the 3.8l v6? Summitt has stage 8 but dont know what size the header bolts are for the 3.8l v6, I did search but couldnt find anything.
          A link to the correct ones at summit would be great. Didn't want to pay $60 with s&h for them at ftpp.net. Thanks.
