i put a 10 Ohm resistor and the check engine light is lit wat should i do?
Iat
This topic is closed.
Re: Iat
Lol :p<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Re: Iat
that thing is worthless anyways dude. you kinda NEED an IAT. its not like an EGR or w/e. if you just put the resistor in there you're basically running rich. that'll kill your gas milage and screw up who knows what else. take that out and put your IAT back in. this rumor was all started by some people just trying to make a buck.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Re: Iat
take it out. you obviously don't understand what doing something so simple like that can effect on your car.
if you continue to want to do this and the code you are getting is caused by this, put in a smaller resistor.
