just placed a kn air filter ( cone ), i just want to know what that sensor with two plug ,that i had to move that was on top or buy the stock filter
intake filter
Re: intake filter
oh ok. well i would re-connect it just to be safe. i replaced all the stock plastic intake pieces that are all mis-shaped and screw up the airflow with a plastic flexible intake tubing from autozone for 25$ i think, then cut a hole in it and stuck the sensor inside then tapped the remaining tiny air gaps from that.
Re: intake filter
Originally posted by av6xperienceoh ok. well i would re-connect it just to be safe. i replaced all the stock plastic intake pieces that are all mis-shaped and screw up the airflow with a plastic flexible intake tubing from autozone for 25$ i think, then cut a hole in it and stuck the sensor inside then tapped the remaining tiny air gaps from that.
Re: intake filter
Are you talking about the headlight box over by the air box? If you are why did you unplug it in the first place? Noithing to do with your intake, just headlights. This is firebird only.1999 Pontiac Trans Am M6 Far from stock.....
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
