I am about ready to get my heads and intake swapped, and I know I need a set of headers and need to slot out a set of bolt holes to get them on after I do it. My question is I have heard bad things about RKsport and how the headers fit, and the only ones I can find from Pacesetter wont work with A/C. I don't want to get rid of my a/c and I want to do this swap. RKsports work?!?!, whats the problems with them? Or should I just be out looking at custom headers?
3.4 Headers and A/C?!?!
Re: 3.4 Headers and A/C?!?!
I don't get it? I've got Pacesetters and A/C. Why do they say they won't work with the A/C? Can you post a link of where you are looking?
Rob\"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
Originally posted by rt1I don't get it? I've got Pacesetters and A/C. Why do they say they won't work with the A/C? Can you post a link of where you are looking?
Rob
But if they fit screw it!1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
I just don't know if they maybe changed the design somehow since I got mine that would make them non A/C friendly. I'm gonna check to see where I got mine from, just a sec, brb.
Well I got mine from CarParts.com. Which was before they got bought out by JC Ripme. Mine are the ceramics also, maybe that's a differance. I guess you could always sell them on ebay if they don't fit.
The Pacesetter headers are for the 3.4 without AIR. Some retailers incorrectly list this as 3.4 w/o A/C but in fact Pacesetter is referring to the secondary air injection found on 3.4 manual trans cars. AFAIK the 3.4 auto does not have AIR.
Most manual 3.4 simply leave off the AIR system when installing the Pacesetter headers. I know that disconnecting the AIR pump will not set off the SES light, however you may not pass emissions sniff test if you require one. From what I can see there is only one injection point on the passenger-side manifold, it would probably not be very difficult to have a hole drilled in the header and a bung welded on if you wanted to retain the AIR tube hookup.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Originally posted by FunkZThe Pacesetter headers are for the 3.4 without AIR. Some retailers incorrectly list this as 3.4 w/o A/C but in fact Pacesetter is referring to the secondary air injection found on 3.4 manual trans cars. AFAIK the 3.4 auto does not have AIR.
Most manual 3.4 simply leave off the AIR system when installing the Pacesetter headers. I know that disconnecting the AIR pump will not set off the SES light, however you may not pass emissions sniff test if you require one. From what I can see there is only one injection point on the passenger-side manifold, it would probably not be very difficult to have a hole drilled in the header and a bung welded on if you wanted to retain the AIR tube hookup.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
