S-pipe - FirebirdV6.com/CamaroV6.com Message Board
S-pipe
  • S-pipe
    If I remember right our stock pipes were 2.25in dimaeter. Ive decided to go ahead and do a 2.5in s-pipe into my borla catback. Does anyone make a s-pipe for our car, or do you have to custom make one at an exhastu shop?
    01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
    AR stage 3 heads/intakes to be installed
    www.cardomain.com/id/firehawknwv
    www.vaperz.com
    PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
    Re: S-pipe
    slp makes an S pipe but its not 2.5, or you can get a U bend from jegs or summit and make one that way ( much cheaper ) but any exhuast shop can fab one up for a fraction of the cost of the slp kit.
      Re: S-pipe
      What size is the SLP piping?
      www.vaperz.com
        Re: S-pipe
        probably 3". my sticky does state that SLP is the only company who makes one. other than that is you custom work.
        2000 3.8 A4 Pewter Camaro
          Re: S-pipe
          Well since I go from a 2.5in straght pipe to the stock s-pipe, by switching it to a 3in S-pipe into my Borla which is 3in I know that would be less restrictive. However, would I gain anythign form it at all and what would it do to the sound of it?
          www.vaperz.com
            Re: S-pipe
            the slp s pipe IS 3 inch, but steps down to around 2 and 5/8's or so, it was just a quick measure when i first got it.
            you could always get a 3"in/out cat or straight pipe and then the S pipe and everything will be 3" and be easy to install.
            you might notice it being slightly louder going from the stock S, but it might not even be noticable.
              Re: S-pipe
              I already had a 2.5in straight pipe, no cat. I wont be puting one back on eihter unless I get a ticket or somethin. I do want to swtich out the S-pipe thogh. So then by using the SLP s pipe it will choke the exhaust some since it steps down?
              www.vaperz.com
                Re: S-pipe
                I also do not find the S-pipe on SLP site so could one of you give me a linky to it so I can see it? Thanx!
                www.vaperz.com
                  Re: S-pipe
                  I got a 2.5 inch S-pipe, from MagnaFlow when I ordered my Cat-Back.
                  1998 White Camaro 3800, A4, MagnaFlow Cat-Back, Zexel & 3.42's, Jet Chip Stage 2, Whisper Lid, and Ram Air.
                    Re: S-pipe
                    from blldoggs sticky
                    http://www.slponline.com/view_produc...45&BIG=30045-1
                      Re: S-pipe
                      off hand, have any of you guys tried using 2 45* bends instead of 2 90* bends.
                      I know I did that on my 3.4L just seems like it would flow better. I had a shop fab it up and didn't have any clearance issues.
                      1993 t-topped camaro to let the rays in.
                        Re: S-pipe
                        some people have done 45* bends...yes
                          Re: S-pipe
                          Decent pricing on the SLP pipe and hardware. Says fits 93-95 model LT1's but u guys say it will fit on our newer six-packs. Should this fit up ok on my Borla cuz Im htinking the Loudmouths I-pipe starts in the same diamter as the Borla.
                          www.vaperz.com
                            Re: S-pipe
                            it will fit your six banger. Lt1 piping follows the same line as ours
                              Re: S-pipe
                              Alright sounds good.
                              www.vaperz.com
