i think i am going to ditch the cat, just in case my o2 sensor was actually correct, but my delimma is should i just do a straight pipe, or get a resonator? i think i have a flowmaster, not sure of the series, and i really dont care about emissions, mainly because indiana doesn't
straight pipe or resonator
Re: straight pipe or resonator
I have a 2.5in straight pipe in place of my cat. So id go with a straight pipe.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
straight pipe - more power than bullet ( very slight if your mostly stock ) but will be more raspy than a bullet. straight pipe will be cheaper too, either way your going to make more power and your exhuast will get louder.
dynomax bullet pic i took a few days ago -
I went with the catco 3 inch cat, made a 3 inch s pipe to a 2.5 reducer and at first I bolted on a 2.5 straight pipe. Not bad, sounded good, but ricey and raspy like no other. Bolted on the flowmaster resonator (its a square thing that is attached to the I pipe) and rasp is very minimal. Of course a v6 will sound ricey no matter what you do. Idle sounds real good with an 80 series.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 hours ago
