I will be getting my whisper lid and high flow filter in the mail Wednesday. Is it safe to take out my MAF screen when I install the lid, or will this cause dirt and debris to clog my intake?
MAF screen?
Re: MAF screen?
Originally posted by UDLOSE98.....suppose a friend of a friend of a friend were to have removed his MAF screen from a 98. what would be not goo dabout doing that, I....i mean he, isnt having any problems with it.;) alot of people have problems when they remove them on 98's. but if your friends friend friend isnt having any problems then i wouldnt worry about it.
Re: MAF screen?
cool, the only problem "he's" having is that when the car is turned on for being ambient and in park it will (rev then almost die, then rev higher then almost die, and keep on going) once put in park, it smoothes out just fine and you are good to go, my fuel trims are looking good, tho I havent checked my MAF reading lately.
Also if you shift back into park once the car has warmed up (2-3 min) tops you can then again put it in park, and it will nto do this.
Re: MAF screen?
Originally posted by UDLOSE98cool, the only problem "he's" having is that when the car is turned on for being ambient and in park it will (rev then almost die, then rev higher then almost die, and keep on going) once put in park, it smoothes out just fine and you are good to go, my fuel trims are looking good, tho I havent checked my MAF reading lately.
Also if you shift back into park once the car has warmed up (2-3 min) tops you can then again put it in park, and it will nto do this.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: MAF screen?
Originally posted by gotchocmilk39so i use the search feature and was hoping to find out how to remove this thing but i didint see anything and i ready dont want to just beat the thing out any help ??1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: MAF screen?
basically I just had my TB off already from pulling my heads, but it doesnt need to be off the car, then I grabbed a screw driver to pop out the little O ring keeping it in place, then I basically "destroyed" the screen witht he screwdriver, being very careful I just kind of pulled it away from the TB.
Re: MAF screen?
well i think the right way is to use snap ring plyers. There are two little holes in the clip that you pinch together or something. i dont know, i have a 98 so i never looked into it that much.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: MAF screen?
Let us know how it runs.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
