my 1996 camaro rs? IF it does how much more am i looking to pay for installation? i appriciate it. thanks
question? Will a 98-02 magnaflow exhaust fit
This topic is closed.
Re: question? Will a 98-02 magnaflow exhaust fit
It will fit. The only difference is the position of the hangar on the driver's side. IF they were to charge you for that, it shouldn't be any more than $8...TOPS!
It should be included in the installation though.sigpic
I am building my own maganflow system though. I wouldn't go with the v6 model for2 reasons. 1 you loose valuable backpressure due to the 3" cat to muffler. and 2 because for your driver side exhaust pipe is like 2 times as long as the other. I am taking the muffler from the trans am kit (14267) and having a shop use my existing cat to muffler pipe (stretch the end because 3" in and 2.5" out). I am then having them put on 2 tail pipes and 3" tips. I went over this with a performance shop owner that i know really well and he said that with the little ammount of torque that we have especially you (3.4) that you need tha backpressure of the 2.25 pipe. He said that If I wanted to go stainless then go no bigger than 2.5" pipe. I went and talked to a muffler shop and with buying the muffler and tips on line it wil be only like 230-250 for the total job.
Originally posted by Brian99I am building my own maganflow system though. I wouldn't go with the v6 model for2 reasons. 1 you loose valuable backpressure due to the 3" cat to muffler. and 2 because for your driver side exhaust pipe is like 2 times as long as the other. I am taking the muffler from the trans am kit (14267) and having a shop use my existing cat to muffler pipe (stretch the end because 3" in and 2.5" out). I am then having them put on 2 tail pipes and 3" tips. I went over this with a performance shop owner that i know really well and he said that with the little ammount of torque that we have especially you (3.4) that you need tha backpressure of the 2.25 pipe. He said that If I wanted to go stainless then go no bigger than 2.5" pipe. I went and talked to a muffler shop and with buying the muffler and tips on line it wil be only like 230-250 for the total job.
Originally posted by Brian99with the little ammount of torque that we have especially you (3.4) that you need tha backpressure of the 2.25 pipe.
it will fit other than the hanger. This got nowhere quick so this is getting locked.
