Where to install cut-out on Flowmaster system - FirebirdV6.com/CamaroV6.com Message Board
  • Where to install cut-out on Flowmaster system
    As many of you know...The Flowmaster system comes with the box looking resonator. Where should I install the cut-out...Before or After the resonator? Or I thought of replacing the resonator with the cut-out. What do you think?
    Re: Where to install cut-out on Flowmaster system
    i put mine after the resonator, if i did it again i would put it instead of the resonator though
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
      do you have a sound clip and how did it make your flowmaster sound
        yea check the sound clips post i posted last
        1997 Camaro LS1 RS
        1994 Camaro - Sold
        A Few Mods....
          i highly recommend replacing the resonator with the cutout or just straight pipe. It'll make it sound 10 times better. Be aware it will be much louder too even with the cutout closed
          2000 v6 a4 Camaro
            what size cutout do you need if you replaced the resonator with the cutout?
              2.5".. You might need a little extra piping too to fill in where the resonator was depending how long the main pipe on the cutout is.
              2000 v6 a4 Camaro
