I recently ran off the road, and completely smashed my left exhaust pipe (post muffler) on my 80 series flowmaster. I simply cut the flattened pieces for a quick fix until FM sent me the new stuff. I just recieved the replacement parts from FM, and I can't get the old piece off! I loosened the U-bolt as much as possible, and the pipe will rotate/wiggle in the muffler, but wont come out...
Also, on my right side where the over-axel pipe goes into the muffler kinda rattles/makes noises...
The only way to get it off is to keep twisting as your prying it out. What probably happened was the U-Bolt dented both of the pipes, and basically mended them together causing a groove.
There IS another solution though, but it requires a welder. I had to do it once. I cut the pipe off just before the muffler flange, then I took a Sawzall and cut straight down the pipe about 3". Pulled the two seperate muffler flanges apart and the small piece of tailpipe came right out. I welded the two cuts afterwards, and then installed the new tailpipe. Worked great!
agreed..theres probably dents in your pipes if you cant get it off you might have to take a torch to it just to side it off...try spraying some wd40 on there to maybe loosen it up a bit more so u can slide the piece out easier
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
