i took off my egr the other day, and made block off plates. what is going to happen if i run it without doing anything to the computer, like a simulator. will it screw my car up?
No EGR
Re: No EGR
nah, might make it rich though (loss of 1 or more MPG)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: No EGR
My car has like 3 codes right now, all of which I know about and planned for. As long as you don't mind running a little rich, or mind the SES light on, don't worry about it. Think about it this way... if you put a flamethrower kit on, it'd just be that much more epic.
You should worry if your state has emissions checks though.2002 Silver Metallic A4 Firebird - All Options
Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
Your Mom or My Dad?
Re: No EGR
will throw a code. I deleted mine and then got rid of the code with hp tuners. Runs just as good as before
Re: No EGR
the egr doesn't lower intake temp, instead it fills the cylinders with COx (think that is what it is called) which takes up spaces and helps burn all the gas and air mixture. Exhaust is hotter than incoming air into the intake. Removing the egr actually lowered my engine temps by 6-8*.
Re: No EGR
i agree that no egr lowers intake temps and like you said it does fill the combustion chamber with a gas but since its already burnt it doesnt burn again making the temp of the combustion chamber cooler because of a smaller fire i believe it will make a little more power all im saying is you going to loose a little timing i guess there really wasnt a point
Re: No EGR
Originally posted by mtcrss2006if u delete that code, will gas mileage go back up to normal? i thought the lower intake temp helped gas mileage, but i'm just a n00b
If you are looking for gas mileage - do Not touch it. You will loose 1MPG if not more and you wouldnt gain any power. If this is good deal - go ahead and do it.
Will throw about 3+ different codes in a while.
Re: No EGR
it will make a little more power at WOT if you dont have the EGR
and it will stop putting all that carbon/heat in the intakes2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
