97 3.8 I have flowmaster 80 on it now, but just the stock pipes. Wanting to run 2.5 or 3' pipe from the headers back to the muffler. I called one shop said they cant get rid of the cat due to the 02 sensor, this true? Need some help here.
Exhaust Help
Exhaust Help
30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>Tags: None
Re: Exhaust Help
They wont take off the cat because you will throw your ses light. Unless you have a reprogrammer and can reset the code dont do it, also you wont pass emmissions. This weekend im putting in a cam, headers and gutting the cat. But i have hp tuners and can reset the code. also if you are heart set on taking the cat off, gut it instead that way it looks like theres somthing there.
so many people are going to tell you to just get a high flow cat because it will be too loud or sound like ****, the only reason im doing this isbecause i have a borla catback and can make my exhaust louder or quieter through block off plates that the borla comes with.
Re: Exhaust Help
Originally posted by silversixxalso you wont pass emmissions.30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
Re: Exhaust Help
Originally posted by 1SL1k30thCamI called one shop said they cant get rid of the cat due to the 02 sensor, this true? Need some help here.\"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
