where can i fined a full CAI for a 94 3.8L that connects to the plenum and has no plastic at all
A full CAI
Re: A full CAI
Originally posted by thechaddwhere can i fined a full CAI for a 94 3.8L that connects to the plenum and has no plastic at all
Re: A full CAI
Originally posted by mtcrss2006If you get one, make sure u get the ChromeIntakes one with the k&n filter. I love the sound it makes. I couldnt really feel a difference until after 4500 where it usually drops off. With the CAI and then SeaFoaming... i got 2-3 mpg better.
Re: A full CAI
Did you purchase one with the plug-in? If so, I would return that sucker as soon as possible. Unless it isn't throwing any codes for not having it plugged in, then in that case I wouldn't worry much with it I would think.
I'm looking at getting the ChromeIntakes CAI that goes down into the fenderwell so all the information that anyone could give on this particular intake from personal experience would be great.
Re: A full CAI
Most people that have them are happy with them. I personally put a LT1 intake into my 3.8. Sounds mean, and like a turbo spooling when you get on it (my friend referred to it as "gurgling with power" when it's at idle) :P . And the further away you can get from the engine, the better. Cooler air = more power. And they should have a spot for the IAT sensor to plug in. If not, you could just drill a small hole into the elbow and push it in there. I don't think your car would run right without that in.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
