Manifold to Y pipe lose - FirebirdV6.com/CamaroV6.com Message Board
  • Manifold to Y pipe lose
    So the y pipe manifold junction is lose on my car. Its loud as hell and rattles a bit. I have the tools to get in there, but should I tighten this up when the engine is hot? I already tried with it cold but could not get much. Not even 1 full turn.
    Re: Manifold to Y pipe lose
    did u try some wd-40 on it thats what i did.
      If nothing works, just cut it in half, remove it, then replace it. A hacksaw, dremel or sawzall will work nicely. You can buy the nut & bolt at almost any auto store for a relatively cheap price.
        is the donut blown out? There is a donut gasket in between that might be blown out and causing the noise and rattles
        http://www.bowtiev6.com/
          Here is a pic of whats going on on the pass side. I didnt try wd-40, but i better wait till it colls down before i do that.
            FOUND IT! Plus Im out here in the dark fixing my car, but **** this is what a y pipe sounds like? DAMN! Acutally a bend south of the cats old place.
            And Might I add damn roolie pollies. What are they attracted to light also?
              I'vs always had problems with that slide connector on my stock setup. I welded it and the rattle stopped, but it's still a sh*tty connection.
              No more worries though since I totally eliminated that connecton with a 3" catback:)
