no cat? - FirebirdV6.com/CamaroV6.com Message Board
no cat?
  • no cat?
    can having no cat. converter make you car run rich for some odd reason mine is and i dont know why?
    Re: no cat?
    that is very possible
      Re: no cat?
      Im catless and run just fine. It will take a while for your computer to relearn its mixture. About the time you start throwing that SES light or a few days.
        Re: no cat?
        It may make the car run lean or rich. Either way it can be tuned. If you are gonna get rid of the cat make sure you get an 02 sim for the censor in the S-pipe. Im runing with no cat and have a sim, but I dont need the sim now cuz Ive had the 02 censors turned off when i got the car tuned.
        01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
        www.vaperz.com
          Re: no cat?
          well its the 3.4 so it doesnt have a o2 after the cat so i cant get a sim. so should i jsut put a high flow cat on?
            Re: no cat?
            of course
            why do you have no cat? cause your old one died?
              Re: no cat?
              Having no cat will not cause a backflow issue. If you got wierd stuff going on its further north then your cat.
                Re: no cat?
                good call
                having no cat will make you run rich for awhile
                but the fuel trims (aka oxygen sensors) should train themselves to bring
                your Air-to-fuel ratio back in line.
                How do you know youre rich? smell? exhaust? hearing it?
                How old are your O2s?
                  Re: no cat?
                  My brother took his off and he is still poor?
                    Re: no cat?
                    removing your cat will not alter your fuel trim. :rolleyes:
                    2000 3.8 A4 Pewter Camaro
                      Re: no cat?
                      I cut my cat. and mine runs fine
                        Re: no cat?
                        you can smell a horrible oder and black smoke but its worst at higher rpm's but it just kind puts out at idle but the smell is horrible people always say stuff about it...and i dont know how old the O2's are, but i have no lights? anyone have any idea's on what it may be? o yea and i just took the cat off for the lil extra boost nothing to ride home about.
                          Re: no cat?
                          hum black smoke horride odor lets see. Okay your muffler is shot man. prolly cracked and clogged. If your cat went your stock muffler aint far behind. Now as far as that ****-in sh!t up? Maybe if it is like clogged. Seafoam your upper intake (just use search to find directions....) change your PCV, then go and get a new muffler.
                            Re: no cat?
                            the muffler was brand new when i put it on and the cat was never shot i jsut took it off. ive done the seafoam as well. and the pcv nothign worked?
                              Re: no cat?
                              black smoke is often a sign of running rich i'd check fuel pressure and o2 activity taking the cat off isnt going to change your fuel trim on a 3.4
