So what if i have the 2.5 cat in/out and with flows,2.5 cat back. will a 2.5 s-pipe balance the rasp a little more? anyone have knowledge on this?
anyone made a 2.5 s-pipe?
Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.Tags: None
Re: anyone made a 2.5 s-pipe?
i doubt a 2.5" VS 3" S pipe will change the sound that much at all. you can make a 2.5" one out of a 2.5" U bend from jegs/summit. just cut it in half, flipe one side over and reweld ( or clamp if you really want to ) someone did a write out in here a while ago, it was for a 3" s pipe but its the same process.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
That's the setup i have on my car. 2.5 in and out cat, 2.5 custom made s-pipe into 2.5 flowmaster exhaust. I can't say if it reduces rasp because I don't know what it would sound like otherwise, but I don't think mines very raspy at all.Old Car = 12.679 @ 106.5 on 150 dry shot.
New Car = 2010 3.6l 304hp Camaro
