Well I hope this is not a repost, I searched for about 30min and found nothing exactly about this. If anyone knows a link about this please post!
Heres the issue...
The cars throwing code's alot if I use my codescanner and clear them they are back in a day or so. So its a reiccuring problem. When I scan the car I get 3 codes:
1. bank1 o2 sensor voltage high/low
2. bank2 o2 sensor voltage high/low
3. another o2 sensor code.
(I can post the EXACT trouble codes if it will help)
But basicly all the o2's are reading incorrect. I have the feeling this could be from alot of things. First off I have pacesetter headers & y-pipe. Also my EGR has been blocked off and I have a borla high-flow cat.
So im not sure if the car is actually running lean or rich or what. Ither way when I clear the codes and have the car running code free it has tons of power and runs great. But big surprize, once the Engine light comes on the car runs SLOWWW.
ANY HELP! would be great, but what do you think I need?
Replace the o2's?
Pick up o2 sims?
If replacing them is the way to go what are the best ones?
Thanks again everyone! like I said, if the exact codes are needed I have a scanner and can post em up. :)
Heres the issue...
Replace the o2's?
Pick up o2 sims?
