So I've gone the route of a 3" pipe and S-pipe, pacesetter headers and a sa-weet summit turbo 3"in/single 3" out muffler. Going for some P&P heads and GT2 gam and supporting mods for that.
So anyway what do you think will give it a throatier sound, a carsound cat or a glasspack or some other muffler in its place? I'm leaning towards the muffler and an o2 sim.
\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
dont put a glasspack there. go with a bullet or a highflow cat. bullet will flow more so more power, but will probally rasp/pop more. if you have to worry about instpection just get a hi-flow cat, they flow great and you dont have to worry about failing inspection.
sounds like a plan... im going for that magnaflow cat after all, that with the 3" in/out summit turbo muffler and my headers should make a nice sound on the stroker motor im building.
