I removed the MAF screen feeling more power and less restriction, and as for the question of is it safe I would say it is, the only thing that it could hurt is if something gets in the throttle body, but if something gets through the airfilter then that srceen isn't going to stop it so if its on or off u can still suck stuff in!!!!!!!
MAF screen removal
Re: MAF screen removal
I've done this free mod. I will def. not recommend this mod. I want to take it back.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
that screen only starts noticably restricting the airflow into your engine at higher horsepower #'s (around 5-600 hp, someone correct me if im wrong). removing it only makes your engine vulnerable to larger debris. ive never heard of dyno proven numbers saying it helps, ive only heard people wanting to put the screen back in.2000 Camaro 3800 A4
Originally posted by Smoke PantherHow can you feel less restriction? Methinks placebo got you by the balls00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
I was gonna take mine out today, but I couldn't get it out. I tried to pry it out, but was afraid I was gonna break it, and didn't want to just in case it made my car run horribly. Any tips to getting it out?~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by hotrod boy 17Well i pretty ******* sure i gained since im gettin more air flow which in turn more fuel, blah blah blah
Google "placebo" and put your screen back in
Don't take it out. It's in there for a reason and any minor restriction it has is not going to effect our cars or very many cars for that matter. It's a friggin placebo.Let's flip a coin. Heads I get tail, Tails I get head.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
