i need some ideas on a custom-cat back. i'm on a budget and so far all of the complet kit catbacks i havent really liked how they sound. Also do cat backs with 2 pipes comin out create more rasp than one with a single pipe?
need some ideas...
This topic is closed.
Re: need some ideas...
This thread will probably end up closed because everyone is going to argue that one catback is better than the other.
Do some more research on each type of exhaust setup, and when you say two pipes are you referring to true duals or just a dual pipe?
It wouldn't really be anymore raspier, but it will be a little quieter in the long run. And for a good catback setup, the majority around here seems to go with Magnaflow (for performance) or SLP, Flowmaster (for sound) and then if you are flowing in the dough right now and can afford something rather pricey get the high and almighty Borla catback.
do a search for those who have done it, what they did and the sound clips for it. opinions mean nothing
