headers - FirebirdV6.com/CamaroV6.com Message Board
headers
  • headers
    im about to buy pacesetter headers for my camaro... a buddy of mine and i are gunna take a saturday and install them, i kno theres a hp gain but how much of it is noticable?
    im still wonderin if pacesetter is the way 2 go... who should i go thru 2 get the headers... i was thinking lm performance.com...
    Re: headers
    headers are headers you wont see any gaping performance from one to the other, they are a good mod tho, will really free up the exhaust and also help the tone of the exhaust.
      Re: headers
      it depends on what kind of engine you have the 3.4 engine will get a decent hp increase maybe alittle more than 10 - 15 HP. But the 3.8 engines already come with tubular manifolds so you'll only get like a 5 - 10 HP increase if that, so not the best upgrade for the money on a 3.8. but headers will deepen the sound on either engine. Just make sure you do it right and watch for exhaust leaks!
        Re: headers
        exhaust leaks are common with the headers, do not over tighten them or they will warp. and use good gaskets.
        2002 Firebird<br />2003 Yamaha YZF 600R
          Re: headers
          only 2000+ came with tubular mani's
          and 10-15 rwhp for teh 3.4 is definetly not refering to RWHP, maybe at the crank that much.
            Re: headers
            i think texas-speed was the cheapest last I checked for pacesetters
            http://www.bowtiev6.com/
              Re: headers
              i second that, i was going to buy from them and then i found a brand new set on here
                Re: headers
                i've had my pacesetters for over 2 years now and the only problem that i've had was my egr started to leak a few months ago. which was fine for me cause i just wanted to block it off anyway. spend a few buck and order the block off plates from zzp.
                WAWA-A-HOLIC
                  Re: headers
                  or you can use some copper RTV and a penny...
                    Re: headers
                    i have the clear image automotive headers, and my egr is disconnected, and have a zzp block off plate.
                      Re: headers
                      www.fasterthanthem.com is the cheapest that i've found
