Me and a bunch of my friends from work had a going-away lunch for one of our guys. When we left, I pulled up to a light and one my friends pulled up next to me, and another behind me. The guy next to me was in a chevy HHR, and started revving his engine, so naturally, I did it right back. Fortunately, I have my flowmasters now so I have something to show off:banana: anyway, the light turned green and we took off. The guy behind me called a couple minutes later and said either smoke, or moisture, or something was coming out of my exhaust when I launched. Does this happen to anyone else? I mean, it's understandable if it does happen when I'm racing it but I also want to make sure that something's not about to break on me.
Smoke
Re: Smoke
Originally posted by UDLOSE98ususally any smoke out of the tail pipes, when the temperature is not freezing is a cause for concern
sometimes from just starting the car its ok....but to be sitting at a light, i would be nervous
Re: Smoke
its probably just cold out side which makes for more visible exhaust
do you know the color of the smoke? was it thick?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Smoke
at that temp and especially going WOT, I wouldn't sweat it. you can worry and check your coolant level for two weeks straight though :D
Re: Smoke
Originally posted by flyfrito_SSBlack smoke is the bad stuff.
Black smoke just means rich which is fine
What IS BAD:
Blue smoke means you have an internal oil leak. (bad piston rings, bad valves, etc..)
THICK white smoke means coolant is leaking into the cylinder (blown head gasket, cracked block/heads, etc....)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Smoke
Originally posted by masonvonritchiei know i didn't roast my tires, i had my traction control on. Anyway, my friend said it was a white smoke, and it was about 50-55 degrees outside. He said it wasn't much, and it was only when I first took off. But hearing that still got me nervous.
Re: Smoke
I knew you were fine2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
