My exhaust pipe just started rattling a couple of days ago. It sounds like it's coming from under of the center of the car,I've looked under there and the only place it's attached is at the cat.I checked the bracket and the bushing it's attached to and it looks ok so I'm at a loss. Has anyone else had this problem?
pipe rattling
Re: pipe rattling
Originally posted by fatcatMy exhaust pipe just started rattling a couple of days ago. It sounds like it's coming from under of the center of the car,I've looked under there and the only place it's attached is at the cat.I checked the bracket and the bushing it's attached to and it looks ok so I'm at a loss. Has anyone else had this problem?
Re: pipe rattling
alot of times its just a heat shield rattling. check the one above the cat and then the one after the S pipe.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Re: pipe rattling
most of the time its a heat shield, or the driveshaft tunnel brace if you want to call it that, but mine however has something broken inside the muffler, just get under there and hit the muffler and see if it rattles
Re: pipe rattling
not so much no. your cat gets really hot. I have seen someones carpet that had caught on fire cause the converter clogged up and basically over heated to where it gets red. that cat HAD its sheilds on :eek:
Re: pipe rattling
I have a brand new high flow 3'' cat with a 3'' s pipe and tsp rumbler - the cat heat shield is rattling and my cat clamp was hitting on it so i just removed it altogether and the rattling is fixed now - but obviously I don't want to risk a fire... does anyone leave it off/ is it OK?
Re: pipe rattling
What year and model car do you have? Do you have a 3.4L or a 3.8L?
I ask because I had an annoying rattle that wouldnt go away and it was because the 3.4L Y-pipe is shielded completely. It has a smaller pipe inside the pipe you can see and mine touches and vibrates. Drives me nuts, only way to fix it is to replace it. I ended up drilling holes and welding fix points to the inside pipe to prevent it from rattling. I hope this is not your problem because it is a PITA.<a href=\"http://home.comcast.net/~beer13oy/carpage.html\" target=\"_blank\"><b>1995 3.4 Liter M5 Camaro</b></a><br />A few mods...<br />still slow.<br /><br /><a href=\"http://www.mnfbody.com\" target=\"_blank\">Minnesota F-body</a>
Re: pipe rattling
I got a 98 3.8 m5. I had to play around with the exhaust a bit after installing the cat+welding the 3'' s pipe and TSP rumbler....It had clearance issues hitting on the rear axle which I fixed but the cat is hitting on the heatshield...so I took it off and its fine now. I dont see how it could burn through the body and carpet - but that's why I'm asking to make sure.
Re: pipe rattling
I welded the S pipe myself from a Jegs U bend. The cat is clamped onto the collector and S pipe - so that's why I didn't have enough clearance with the clamp. Now with the heatshield off, its not hitting or rattling anymore. I just wanted to know if its fine to run with no cat heatshield shield (possible fire hazard? etc..)
Re: pipe rattling
Originally posted by lubsvitekI welded the S pipe myself from a Jegs U bend. The cat is clamped onto the collector and S pipe - so that's why I didn't have enough clearance with the clamp. Now with the heatshield off, its not hitting or rattling anymore. I just wanted to know if its fine to run with no cat heatshield shield (possible fire hazard? etc..)1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...2 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...4 days ago
