pipe rattling - FirebirdV6.com/CamaroV6.com Message Board
pipe rattling
  • pipe rattling
    My exhaust pipe just started rattling a couple of days ago. It sounds like it's coming from under of the center of the car,I've looked under there and the only place it's attached is at the cat.I checked the bracket and the bushing it's attached to and it looks ok so I'm at a loss. Has anyone else had this problem?
    Re: pipe rattling
    Yes. See if it is touching the cross member. If it is just get a pry bar and lift it a little. It must be touching something somewhere along its path.
      Re: pipe rattling
      alot of times its just a heat shield rattling. check the one above the cat and then the one after the S pipe.
        Re: pipe rattling
        mine was rattling like that and all i did was put 4 washers on each cross member bolt and that fixed the problem
          Re: pipe rattling
          i used a metal clamp (hose clamop i think)to fasten the heat sheild back down to the pipe.
            Re: pipe rattling
            most of the time its a heat shield, or the driveshaft tunnel brace if you want to call it that, but mine however has something broken inside the muffler, just get under there and hit the muffler and see if it rattles
              Re: pipe rattling
              Is it safe to remove the heatshield above the cat?
                Re: pipe rattling
                not so much no. your cat gets really hot. I have seen someones carpet that had caught on fire cause the converter clogged up and basically over heated to where it gets red. that cat HAD its sheilds on :eek:
                2000 3.8 A4 Pewter Camaro
                  Re: pipe rattling
                  I have a brand new high flow 3'' cat with a 3'' s pipe and tsp rumbler - the cat heat shield is rattling and my cat clamp was hitting on it so i just removed it altogether and the rattling is fixed now - but obviously I don't want to risk a fire... does anyone leave it off/ is it OK?
                    Re: pipe rattling
                    What year and model car do you have? Do you have a 3.4L or a 3.8L?
                    I ask because I had an annoying rattle that wouldnt go away and it was because the 3.4L Y-pipe is shielded completely. It has a smaller pipe inside the pipe you can see and mine touches and vibrates. Drives me nuts, only way to fix it is to replace it. I ended up drilling holes and welding fix points to the inside pipe to prevent it from rattling. I hope this is not your problem because it is a PITA.
                    <a href=\"http://home.comcast.net/~beer13oy/carpage.html\" target=\"_blank\"><b>1995 3.4 Liter M5 Camaro</b></a><br />A few mods...<br />still slow.<br /><br /><a href=\"http://www.mnfbody.com\" target=\"_blank\">Minnesota F-body</a>
                      Re: pipe rattling
                      I got a 98 3.8 m5. I had to play around with the exhaust a bit after installing the cat+welding the 3'' s pipe and TSP rumbler....It had clearance issues hitting on the rear axle which I fixed but the cat is hitting on the heatshield...so I took it off and its fine now. I dont see how it could burn through the body and carpet - but that's why I'm asking to make sure.
                        Re: pipe rattling
                        You shouldn't have any issues as long as the body is not making contact with the body...but install properly, you shouldn't have any clearance issues. Was it a custom S pipe? Did you hang the axle back before making your welds?
                          Re: pipe rattling
                          I welded the S pipe myself from a Jegs U bend. The cat is clamped onto the collector and S pipe - so that's why I didn't have enough clearance with the clamp. Now with the heatshield off, its not hitting or rattling anymore. I just wanted to know if its fine to run with no cat heatshield shield (possible fire hazard? etc..)
                            Re: pipe rattling
                            its fine, i dont have one and never noticed a issuse. LOTS of people run around with out them.
