exhaust manifold>removal driver side - FirebirdV6.com/CamaroV6.com Message Board
  • exhaust manifold>removal driver side
    hey guys,
    i searched around and found a few things but not exactly what i needed to know.i was wondering what size is the nuts on the studs for the manifold? also which bolts need to be removed from the top,and which from the bottom? from the looks of it i don't know how i can remove the darn thing.
    will i have to unbolt the y pipe to to get the manifold off?
    btw i am removing it because i broke my egr bot off in the manifold and i can't remove the bolt without taking the manifold off anyways.so i got one from lilchubby and i am just gonna put another on it.please help me out guys,i have enough under my belt trying to gt my mr2 spyder's motor back in it.i haven't drove it in over a year.now i have this to deal with to ,sorry to be a whine sack. :banana:
    Re: exhaust manifold>removal driver side
    search. 97rs4life made a writeup
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
      you have to drop your exhaust system (the y pipe needs to be completely out of the way) take off the egr tube, then take off the i think its 6 or 8 bolts holding it on, then it drops right out the bottom, dont bother trying to get it out of the top, it doesnt work
        I'm assuming this is on a 2005 honda??
          http://forum.camarov6.com/showthread.php?t=58256
          i saw it before i started this thread but thank you.i have been a member on spyderchat.com for awhile now so i know what it is like to answer a post on say-
          "what is seafoam?"
          i try to make sure there is nothing that relates to my exact question before i take up some more of your bandwith. lol
            2007 the new one,come on get with the program already. :rolleyes:
            lol
              thanks man that answered on off my questions about where it comes out from and taking the y pipe off.i know 97rs4life wrote to take off the y pipe but that was also so you could weld in the new one. appreciate it.
              does anyone know what size or should i just start feeling around?any more tips? after breaking that egr bolt off in the manifold it's got me scared to fool with the studs on the head.
                why not delete the egr and weld the hole shut. thats what i did.
                1997 Camaro LS1 RS
                1994 Camaro - Sold
                A Few Mods....
                  i don't know how to weld (big surprise right lol) but can it be done while in the car?and then i could just put a filter on the egr tube should be good to go....
                    okay according to 97rs4life a filter on the pipe is fine,so nothing needed except welding the hole shut.i few people reccomended welding it with high heat silicone and some change but also they said it blew off.so how dangerous is it to do this with the manifold in the car?
                    did you weld it in the car Tom Rs?
                    thanks man.
                      if an experienced welder does it it should be fine in the car, i would not silicone it, and imo putting a filter on the tube isnt even nessicary, because i'm not thinking the egr will even open without the exhaust going into it, and at that it isnt sucking, it takes the force of the exhaust to push it in
                        thanks man.
                        yes my brother did it for me in the car. it was tig welded. perfectly fine. he's been a welder for over 10 yrs now though
                        1997 Camaro LS1 RS
                        1994 Camaro - Sold
                        A Few Mods....
                          okay man,thanks for the tip.anything that can save me some money. btw i think i will atleast put a screen on it to keep any bugs or anything else out of it though.
                            okay well i will give it a try,now i just need to find someone who will do it.since it tampers with emissions i don't know if an exhuast shop will do it.but thanks alot guys,you just took alot off my shoulders.now if i can just get the motor back in my spyder. lol
                              I mig welded my exhaust manifold's open-hole shut (didnt use anything except the welder)
                              You dont need a filter on the intake side. Just make sure its blocked off
                              n00bs: You dont even have to remove the egr, just unplug it!
                                6 days ago
