I have an aftermarket muffler, but stock cat. When im in low gears in low rpms, theres this loud annoying rattling sound... like the muffler is loose or something. I took to to they guy that put it on and he said they muffler wasn't loose. So do yall think the stock cat is the problem?
vibrating noise...
Re: vibrating noise...
if you have ramps, use them and check and see how close the exhaust is to the body or something else it could contact, might try and shake it alittle(the exhaust). mine does this too and i just need to get the time to fix it.
having the stock cat shouldnt effect anything as long as the exhaust was installed right.2002 NBM Pontiac Firebird Formula<br />Mods: stock...<br />1997 Chevy Camaro *Gone*<br />Mods:Borla,headers,Magnaflow cat, SLP intake, NOS 5175
could be many things. i suggest the same as Silv6. check under there and see if any pipes or anything are close to the heat shields or if there is anything you can see visually that might be causing it to vibrate/rattle. shake around the pipes and see if you notice anything too. might just be a loose bolt or something somewhere that needs to be tightened up. also, a good way to see if the cat is whats causing your noise.. is to bang on it a little and see if you hear stuff rattling around.. if you do: time for a new cat.Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
I had the exact rattling noise problem you're describing, a rattle or buzzing sound in lower gears. I took my bird to the mechanic just yesterday for them to check it out.
They told me today it is in fact the cat. He believes there's a broken ceramic fragment inside rattling around. I'd suggest you start by checking out your cat.
i have a rattle too, but its in my muffler, so something in there is broken, so i'm just redoing my entire exhaust with a rumbler and catco, slowly but surely i am getting there, i think there is a flowmaster on there now, was on when i bought the car
Originally posted by WarmMachineMEI had the exact rattling noise problem you're describing, a rattle or buzzing sound in lower gears. I took my bird to the mechanic just yesterday for them to check it out.
On a funny note, the mechanic that was looking at it told me it was the clutch going out. I told him, :bs: , a bad clutch wouldn't make it not rev past 2K. He said, "sure it will; it's slipping." I said, "Slipping would cause it to tach way up without moving." He then said, "Who's the mechanic here?" to which I answer, "I'm wondering that myself."
Lounge Moderator
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...8 hours ago
