I'm looking to buy an upper and lower intake manifold for a project vehicle from a 3800. Before I buy one, I need some good, detailed pics of the upper intake from a 95-98, and 99-03. I need to know what the differences are between them. TIA, David.
Need pics! 3800 Differences???
Re: Need pics! 3800 Differences???
simply put... angled TB to straight TB... thats basically the only difference. i can get you some detailed pics of basically anything you want... i have 2 3800's waiting to be built right now... so let me know if you need pics.
The 95-98 has a throttle body that uses a cable linkage set-up. I believe the 99-03 uses a drive-by wire, no cable linkage, which requires the use of sensors. I don't think you will be able to mount the cable linkage throttle body on the 99-03 intake manifolds. Not without modifications anyway. Also, like rdrr96 mentioned for the 95-98 intakes where the throttle body mounts to, it is angled downward, where as the 99-03 is straight out. Send me an email address and I can send you pictures of both intakes. My email address is: Chevyone@hawaii.rr.comLast edited by 3.8L Strong; 03-16-2007, 12:23 PM.
Originally posted by tonloc22speaking of intake manifolds where can i find aftermarket ones
why do you guys keep putting 99-03? you guys sound like some retarded salesman. its 99-02.
Originally posted by 97rs4lifeyou can't because nobody makes any, only stock ones that have been ported.
you could always make one yourself... i was talking to a couple guys locallyto make me one or a couple. if i do get it done ill post pics and stuff like that. theyll keep the blueprints so they can make moreand what not. illl talk to them and see if they are willing to try it out.
Originally posted by dcatmichI'm looking to buy an upper and lower intake manifold for a project vehicle from a 3800. Before I buy one, I need some good, detailed pics of the upper intake from a 95-98, and 99-03. I need to know what the differences are between them. TIA, David.
Raven
Sweet. Thanks Robert. Any signifigance in flow, or inlet/outlet size between the two? Anyone better than the other? Differences in TB are not a factor, I will be using a diff style for that.Thanks again guys.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
