Bipassed Resonator? - FirebirdV6.com/CamaroV6.com Message Board
Bipassed Resonator?
  • Bipassed Resonator?
    I've been wondering what this is. On Kristen's description under her car on the Featured F-Body, it says she has one? Any idea?
    Re: Bipassed Resonator?
    it means that she cut out the i-pipe and put a straight pipe in place of the Resonator.
    -Y87
    Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
      so that big resonator box that came with my Flowmaster exhaust is just taken out? Put a straight pipe in?
      And by the way...how much sound does that resonator really actually reduce?
        i havent done it yet but i herd it makes alot louder on the inside and it problily sound better on the outside. but i dont know how much rasp you will notice when you take it off.
        btw if you dont like it you can always weld it back on:)
        -Y87
          you wont regret taking it off... it sounds way better with it off
          2000 v6 a4 Camaro
            so i can just buy a regular resonator pipe with no box or anything from farm n fleet or somewhere, stick it on, and it should make a good difference?
              Just go to your local autoparts store and get a 2.5" piece of pipe about a foot long... make sure the ends of it have a 2.5" inner diameter so that it will slip over the existing exhaust where you cut the resonator off. Clamp it together, and then take it to a shop to get it welded.
              2000 v6 a4 Camaro
                just get a pipe with only one 2.5 ID end. Then expand your i-pipe where you cut it so you can slide it in.
                  it really does sound better. just have to work with what you have in your set up. i took a gamble doing it with mine with my intake, headers, exhaust etc. what is your full set up?
                  WAWA-A-HOLIC
                    could you post a pic of what you did?
                    -Y87
                      I would think that having to expand the I-pipe would be more work than getting a pipe that would already fit over it?
                      2000 v6 a4 Camaro
