I do not have the technical skill or know how to pull this off, but it is an idea to try for someone who has the skill. My idea would be to take a tuned port injected in take and throttle from a v8 Camaro/Firebird/Corvette and cut off two of the pipes and block them off. Then rebuild the other pipes coming off the intake to fit a 3.4L v6. I believe if the pipe fabrication coming off the intake is done properly this will work so that not only will you have a better flowing intake manifold, but you will also be able to make use of the bigger throttle body. What do you think? Anyone think they have the skills to do it? Any reason why this won't work?
Just and idea.
