97 Camaro with 2.5" MagnaFlow Cat-Back system with gutted stock cat and Z-28 tips. And it has quite alot of rasp. I was thinking replace the gutted cat with a Bullet, but idk. What would you guys recommend for a cheap fix to this? I've got an O2 Sim, so I don't have to worry about throwing a code.
Rasp Needs to go
Re: Rasp Needs to go
yeah, definately put a bullet on there. either replace the gutted cat or on your i-pipe.
try this:
http://store.summitracing.com/egnsea...115+4294783279
well, camaro862gcj has one for sale on here. It's the Dynomax Ultra Flow bullet. Was thinking about buying it, but wasn't too sure if it would help or not.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
gutted cat isnt helping matters, id swap the gutted cat out for a bullet.
the rasp will never go away, it'll always be there, so dont expect it to completely go away.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Originally posted by Sean_99_3.8i didnt know you could breakin exhausts...i say thats total:bs:
personally my exhuast got quiter, and it didnt pop as much. i knew exactly what rpm i could let off and make it pop, and that changed after a while, and now it changed again after the headers.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
no emissions in FL :D I don't want to mellow the sound, I like it the way it is, just don't want it to be as raspy. Think I'm just gonna get the bullet (if my parents let me that is :( )~97 3.8L V6 Camaro~
A few things
