I was at advance auto parts and seen this big air cleaner that looked like it would fit right on the intake. I was wondering if i could just stick that right on the intake and put AIT sensor in the short tube and if would see any gains. Otherwise i was going to take some metal tubing and put the air cleaner in the stock location so it would be like the K&N CAI intake. Will these ideas work. In the future i plan on building cheap 3in exhaust. The air cleaner is only like 25$.:)
New intake idea
Re: New intake idea
It would work, and you may see some gains. It'll probably sound louder, and have abit better airflow, but you're still sucking in hot air right from the engine bay. I'd say make one with tubing, and when you do take it all the way into the fenderwell, that way you get good cool air.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: New intake idea
yea i got the idea from muscle car tv when they installed a ram jet. Also my budgets extremely low because ive only had my liscense less than a month and i still need new bumper for my 02 camaro because i learned the hard way why not to drive in the winter without being carefull.;)
Re: New intake idea
don't think that would be a good idea...I think you will get less airflow and the air you do get will be hot engine bay air...
but the filter at the stock location and replace the restrictive intake 'tubing' with some free flowing tubing1999 Camaro Z/28
1973 Firebird Formula
Re: New intake idea
Originally posted by badinfluenceRSdon't think that would be a good idea...I think you will get less airflow and the air you do get will be hot engine bay air...
Re: New intake idea
do u think i should modify the stock air box cover by cutting out the little divider were the air leaves the air box. Also i cant aford a different filter so would just changing the tubing and keeping the stock air filter. My other optionn was like RadRacer said to locate the filter in the fender well. Wat would give me the most power gain.
Re: New intake idea
I didn't take a look at your name ealier. From it, I'm gonna assume you have an '02 Camaro :P Anyways, since you have the intake lids, cut the fins inside it and replace the rubber hose with a peice of PVC or metal tubing. Then cut out the bottom of your airbox if you want to get some cooler air in. I'd do all that instead of taking it into the fenderwell. I only suggested moving it to the fenderwell because i though you had a pre-98 car, and they have different intake.~97 3.8L V6 Camaro~
A few things
Re: New intake idea
well for now i just removed the air box silencer thing and replaced that with some pvc tubing we had lying around. I had to wrap alot of electrical tape around the tube and and used the stock couplers. Test drove it and seemed alittle bit quicker. cracked tires loose at 1/4 throttle. Stupid open diff.
Re: New intake idea
Originally posted by 02bluecamarowell for now i just removed the air box silencer thing and replaced that with some pvc tubing we had lying around. I had to wrap alot of electrical tape around the tube and and used the stock couplers. Test drove it and seemed alittle bit quicker. cracked tires loose at 1/4 throttle. Stupid open diff.
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...3 days ago
