I recently put an SLP cold air intake on my camaro and to do so I had to remove a splash guard that had a few air vents but after I installed it I decided to leave the guard off. Should I put it back on, or will it make a difference either way?
quick cai question
Re: quick cai question
you wont notice a real performance difference. put it back on if youre worried about water getting in there, but otherwise leave it off. mine's been off for years.
I have th FTRA intake and Ive had no problems with water getting sucked into the intake. Ive had the blockoff plate off ever since I installed it over 2 years ago. The FTRA kit comes wiht a seal that seals off the front of the air box which gives it a (as FTRA describes it) small supercharger effect to the intake. Meaning the faster you go the more power you get from the intake though its not going to be of great significance to begin with. However, I say leave teh guard off cuz you shouldnt have any problems with water getting sucked into there unless you hit a deep puddle hard.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
AR stage 3 heads/intakes to be installed
www.cardomain.com/id/firehawknwv
www.vaperz.com
PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
Originally posted by ZO6vette037Firehawk N Wv I think he has the 93-97 style intake, not the air box from the 98+ f-bodies, so there is a bigger chance of him getting water in the intake since the filter sits right above the splash guard.
Originally posted by Chevy16the intake is going to be in about the same exact spot on both the 98-02 and 93-97 models
One is near the top of the radiator and the other is tucked down into the fender.
im sure hes referring to the lt1 style intake. leave the splash guard off, you wond need it unless you head underwater.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 hours ago
