went and had my codes scanned at autozone, hehe - FirebirdV6.com/CamaroV6.com Message Board
  • went and had my codes scanned at autozone, hehe
    so my SES light has been on ever since i got my headers installed, but the car hasnt been driving right, so i wanted to check and make sure nothing else came up.
    i walked into autozone and asked the lady if she could check it for me. she came out, plugged the thing in. after a minute or two, she just looked at me and said "wow! i hope you have a warranty on this car!" so i asked her what code it was throwing, at which point she told me there were 5. so i asked her which, and she said that it was my front and rear o2 sensors, and my catalytic converter. i just laughed, and said that it was good news. she got really weird, and told me that it was a serious problem... and was quite surprised when i told her that i caused it all, knowingly.
    i just wanted to make sure it wasnt a misfire or something!
    i know that my egr is part of the problem. so that is going to be fixed shortly. but what should i do for the others? is my best bet to get some o2 sims? have it tuned? anything else?
    2002 SOM Camaro- Sold
    2006 S60- Sold
    2000 Cherokee- The desert whip
    Re: went and had my codes scanned at autozone, hehe
    When I had my headers installed the shop told me that its common for O2 sensors to go bad afterwards. Replace the O2 sensors and you should be fine. I had to replace mine after 500 miles with the new headers.
    Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
      get the o2 sim. i had the same problem. 3 mins of work and it was fine
      WAWA-A-HOLIC
        do i need an o2 sim for every sensor? or is it just one?
        2006 S60- Sold
          isn't it supposed to be the 2 upper o2s? I know on my car those were the only sensors that were *****ing, i wired in the sims and that was it. if you know someone with hp tuners they can go in and just turn it off that way to.
            I think they only make a sim for the after cat sensor. I've had my headers on now for about 5k miles and haven't thrown a code. I have heard of them going bad, should it throw a code if they are bad or should i just replace them?
            Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
              Yea, my 02's went bad after I installed my headers as well. I replaced them and it threw the code again. I just had the codes tuned out and my 02 system turned off with the tune. No problems has resulted because of that.
              01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
              www.vaperz.com
                what could cause the front o2's to go bad?
                2006 S60- Sold
                  The sim is for the post-cat sensor.
                  1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
                    yep, i wouldnt put them on the front 2, their alot more important.
                    usaully just the post cat 02 sensor throws a code from what i understand. mine only threw ( still throwing ) one for the post cat.
                    btw, 02 sims are hit and miss, i have one and it worked for a month or so, then the light came back on. other people have this problem too, just have to tune it out or live with it i guess.
                      Holy **** i can not believe what I am reading. the post cat 02 sensor is the only sensor that doesn't really matter and get be tuned out or simmed. the front two are extremely important to engine drive-ability.
                      2000 3.8 A4 Pewter Camaro
                        i know that the front 2 are more important. what could be causing them though??
                        the egr?
                        2006 S60- Sold
                          ^what he said.
                          steve- how many miles are on your car? They may just be worn out.
                            Originally posted by caspernicus
                            ^what he said.
                            35xxx...
                            2006 S60- Sold
                              Originally posted by stevethepirate
                              35xxx...
                              high milage and running rich are the most common reasons i belive.
                              whats wrong with your egr?
