anyone know how? my car has a bad exhaust rattle at certain low cruise speeds around 40mph, and nowhere else that is causing me to have false KR. anyone know any ideas to get rid of it? the exhaust isnt hitting anything, it just rattles and causes the car to shake a bit. . maybe there is nothing to get rid of it?
how to get rid of exhaust rattle?
Re: how to get rid of exhaust rattle?
where about it is coming from? i have one too, at low rpms somewhere in the rear section of the exhuast, on the passenger side.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
i cant tell where its coming from. and im 100% positive its not hitting anything. checked the motor mounts and i checked the tranny mount as well... im still stumped.Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
i have the same problem, nothing is loose to my knowledge though. ive had the problem since the day my catback was installed =\1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
Do you still have a cat on it? If so check the heat shield on it or if a small rock has made its way in the heat shield.91 Firebird 3.1<br />SC12 Supercharger<br />LSD w/ 3.73s<br />NOS 80hp wet shot<br />AKA: Phoenix<br />\"If Speed Kills...Consider Me Dead.\"
Seems we all have that problem then.. i figured it was part of my roof assembly that was just rattling....
Originally posted by SSMOWS6i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
Still... 18-1 > 1 and done
Well the only thing that I think it might be if its the exhaust is the over axle pipe. Our cars have a lot of vibration and I'm thinking its the over axle with the heat shield above it. I know my system is different from yours but you can go grab any part of the rear exhaust and thrash it and try to rip it off and it doesn't move a bit but when I ideal sometimes it rattles. Also if you go under there and the pipe moves alittle but doesn't hit anything the heat from the exhaust might be making your pipe expand just enough to make it rattle.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
