Can you drill a hole into a S-pipe for an O2 sensor and seal it up? Not concerned about throwing a code as long as it runs fine, emissions are not a concern.
But what can I use to seal the sensor in there? Hi-temp silicone?
if you're not concered about throwing a code, then just unplug the sensor or zip tie it somewhere underneath the car. Doesn't have to be in the exhaust, it will still run fine, just think your o2 sensor is broken or your cat is, hence the code
