Magnaflow and SES light code, update from 01 May - FirebirdV6.com/CamaroV6.com Message Board
  • Magnaflow and SES light code, update from 01 May
    Thanks for the replies,
    I checked back with the garage and they said the code was P0134
    My book says o2 Pre-convertor left bank no activity.
    when I purchased the three o2 sensors I remeber they looked the same with a blue electrical connector and four wires to each one. I don't have the bill anymore so I can't check the part code. I thought that all the three sensors were the same on the 98+ cars??
    what do you think??
    Vic
    Re: Magnaflow and SES light code, update from 01 May
    they are the same
    2000 3.8 A4 Pewter Camaro
      If the code is P0134, does that mean the sensor is the one in the drivers side header. From the previous thread how would swapping sensors around help, like upstream and downstream if they are the same??? Upstream and downstream from where?? Electronics not my strong point so please humour me.
      Thanks
      Vic
        it is the sensor in the drivers side header. you can switch it with the passenger side header and see if the code changes. :)
        search the code, code diag info
