Got my ported and polished throttle body in the mail today. Bought it from 'Funkz' on the boards. Took me 20 minutes to get it on and running, didnt have to adjust anything. I went ahead and did the coolant bypass while I was at it. It no longer feels like im stressing the engine past 5000rpm. Also noticed the increased wheel spin from the added/relocated power I now have :cool: Well worth it for you 3.4 guys.... Thanks Zahn
3.4 P&P throttle body installed
Re: 3.4 P&P throttle body installed
Originally posted by lubsvitekIts good that you're happy, but you won't be gaining any increase in hp that would translate to added wheel spin from a P&P throttle body
I can feel it and hear it, im getting wheel spin a few hundred rpm sooner then usual. I used to have my 2 step rev limiter set at 2600rpm before the throttle body swap. Now when I try to launch at 2600 she just wants to spin. LSD going in later this summer :)
Wow, that got to you fast! LOL I didn't figure you'd have it until tomorrow.
Glad you're happy with it, got any pics of the before/after install?
The stock TB bump stop won't allow a full 90° open, so the TPS never registers 100% throttle. Modifying that and the other work done does give the 3.4 a much more responsive throttle.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Originally posted by FunkZThe stock TB bump stop won't allow a full 90° open, so the TPS never registers 100% throttle. Modifying that and the other work done does give the 3.4 a much more responsive throttle.
Sure, no problem. You don't have to clean it though, I give them a thorough parts wash when I'm done with em. :)
Good to hear SF! Just shoot me an email when you're ready.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Originally posted by 97rs4lifewhat? Port/polishing your TB isn't exactly a power adder.... It's true, every little bit helps and its good to clean it out but realistically, how much hp do you think it adds? 1...2? Even adding full intake isn't exactly going to break your traction sooner. I did it when I was replacing my upper intake gasket & TB gasket, but didn't see noticable gains in it. Like I said, its good to keep it clean because a lot of carbonates pile up in there, but if we're feeling any gains its most likely our butt dyno's talking.
Originally posted by lubsvitekwhat? Port/polishing your TB isn't exactly a power adder.... It's true, every little bit helps and its good to clean it out but realistically, how much hp do you think it adds? 1...2? Even adding full intake isn't exactly going to break your traction sooner. I did it when I was replacing my upper intake gasket & TB gasket, but didn't see noticable gains in it. Like I said, its good to keep it clean because a lot of carbonates pile up in there, but if we're feeling any gains its most likely our butt dyno's talking.
Originally posted by mlsFiTI believe 3.4s make almost 200 crank hp at 2500rpm then flat line, its basically a truck engine ;) So what if that 200hp is now coming on 200rpm sooner?
